Car shut off while driving
1999 VOLKSWAGEN JETTA
177 MILES • 2.0L • 5 CYL • 2WD • MANUAL
MSLEAH
Please help. I just bought this car. it has always had a strong gas smell, poor gas mileage, it will shut off if car goes under half a tank of gas. When i fill it up it will not start unless i pump the gas, it then runs rough briefly but seems to correct. Recently while driving my engine light came on and was beeping and flashing causing car to run rough and lose power. I then blew my oil cooler gasket. I just replaced it. I was driving and car just stalled and would ont turn back over. I ran the code which read cylinder one misfire. I had a compression test done which showed 10 psi on cylinder one. I was told to cut my losses and scrap the vehicle. please help. I have put so much into this vehicle i cannot just throw it away as it is my only means of transportation for me and my children.
Jan 19, 2018 at 1:47 AM
Good morning.
The first step is that the engine has a serious issue. low compression requires the cylinder head has to be removed and the engine inspected for damage. it may turn into needing either a complete rebuild or replacement with a used engine.
The first step is to determine why or what caused this failure.
Jan 19, 2018 at 3:33 AM
MSLEAH
Yikes! i guess I cut my losses as I cannot keep throwing money into further diagnosis. Sad sad day.
Jan 19, 2018 at 8:11 AM
Sorry to hear that. you could consider a used engine.
Jan 19, 2018 at 8:20 AM
