Good afternoon,
The code is for the crank sensor. If the signal is lost to the ECM, the engine will not run.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
I attached the location and the description for you of the sensor.
Also, remove the connector and make sure you have a 5 volt signal to the sensor.
DTC P0336 - CRANKSHAFT POSITION SENSOR CIRCUIT RANGE / PERFORMANCE PROBLEM
DTC DETECTING CONDITION:
Immediately at fault recognition
TROUBLE SYMPTOM:
Engine stalls.
Failure of engine to start
CAUTION: After repair or replacement of faulty parts, conduct CLEAR MEMORY MODE and INSPECTION MODE. Refer To How To Clear Diagnostic Trouble Codes.
WIRING DIAGRAM
Jan 15, 2021 at 1:50 PM
