Vehicle shut off at stop light and will not start
2005 NISSAN ARMADA
230,000 MILES • V8 • 4WD
MARTIN PEREZ
My vehicle listed above came to a stop and shut off on me. i thought it was the battery because it was getting bad but in replaced it. all lights turn on inside but the dashboard and it won't start.
Jan 16, 2021 at 10:05 AM
When you say it is not starting, does the vehicle even crank and not start or does it not do anything when you turn the key? Here is a guide that we need to run through if it is not doing anything:
https://www.2carpros.com/articles/starter-not-working-repair
If it cranks but does not start then we need to start with this guide:
Also, here is a guide that will help with checking fuel pressure which is the first thing we need if the engine will crank but not start:
Let's start with this and then go from there. Thanks
Jan 17, 2021 at 5:00 PM
