Did you get it towed home or to a auto repair shop?
Do you know how to use a 12 volt test light, a voltmeter and do you happen to have any and know how to use starting fluid?
If so, see if the engine will start and run for a few seconds after spraying a few small shots of starting fluid directly into the throttle body then quickly making it to the ignition switch and crank the engine over.
If it starts and runs for a few seconds then the ignition system must be ok. If it doesn't start either check for a spark from a spark plug wire while cranking the engine over or if you are not comfortable doing that, at least check the ignition fuses and make sure the ignition coil/s has voltage to it when the key is on run/ engine off.
If the engine did start with the starting fluid and the fuel pump does run, most likely the fuel injectors are not working. It could be as simple as a blown fuel injector fuse or blown pcm fuse, a security issue shutting down the engine or possibly a faulty crankshaft position sensor and if so there should be a trouble code for it stored in the computer memory, for which can be retrieved with a scan tool or a code reader.
If you have a voltmeter or at least a 12 volt test light, check if the fuel injectors are getting voltage with the key on run/engine off.
Feb 14, 2018 at 5:33 PM
