Okay, can you double check the connector going to the fuel pump again. If the connector is okay then can you please double check the fuel pump fuse which is located in the Power Distribution Center in the right rear of the trunk. It is fuse 6(20A). If the fuse checks out okay, then can you please check the voltage a pin #5 of the fuel pump connector. Or will need to use a digital multi-meter to do this and below is a link explaining how to use a DMM, if needed. Also here is a link for how to check fuses, if needed, as well:
https://www.2carpros.com/articles/how-a-car-fuse-works
In the diagrams down below I have included a wiring diagram of your vehicle's fuel pump, a diagram of the connector and a diagram with location and callout for the power distribution center. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 26, 2019 at 4:10 AM
