Engine cranks but does not start after being in a flood of water?
2006 ALFA ROMEO BRERA
142,390 MILES • 2.4L • 5 CYL • TURBO • 2WD • MANUAL
OZZMAN1970
Got caught in flood water, car shut off. Got it home on flatbed, dried out and started. Drove a few miles then the engine management light came on.
Got it back home. Starting as normal. Engine management light went off.
Car then wouldn't start. Checked fault codes and replaced cam and crankshaft sensors. Codes are no longer coming up but car still cranks doesn't start.
Oct 20, 2023 at 8:53 AM
What codes were present prior to replacing the parts? Let me know if you still have them.
Next, a crank no start condition is usually the result of either a fuel related issue or ignition. So, here is what I want you to try.
First, see if the engine will start if you use starting fluid. If it starts and then stalls, we have confirmed it is fuel related. If there is no change, I need you to check for spark at the spark plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Also, if possible, could you record the engine cranking and upload it for me to hear? That may be very helpful.
Oct 20, 2023 at 9:44 PM
OZZMAN1970
Hi Joe, thanks for getting back to me.
Not had chance to work on it because of work.
I had wondered about the fuel so will be checking that as it does start with Easy start but then stalls.
I forgot to say it didn't aqua lock when caught in the flood water.
This particular model doesn't have spark plugs.
I'll get a recording of it cranking and I'll try to get the codes.
Take care
Mike
Oct 24, 2023 at 11:23 AM
JACOBANDNICKOLAS is one of our best! Please let us know when you can upload the video, it will help.
Oct 24, 2023 at 1:56 PM
