I have a problem with my Nissan Micra 2004. When I turn on the car and it is cold the motor fan starts working and the blue light on the the dashboard is on. The overdrive light starts flashing, when running the vitesse hits when the gear chage fram 1st gear to 2nd and the rpm stops working. When turning the car off it won`t turn on again. I went to an electrical technician and he changed the fuse box placed behind the left headlight but the problem wasn`t solved.
I also changed the battery but the problem was not solved. I noticed that when the problem occurs the check engine light is not on after turning the key on contact. Please can someone help me, thanks ...
Best regards ...
Best regards ...
May 20, 2013 at 11:23 PM
