How do you wire a pair of 6x9 speakers to a 2-channel amp?
2000 HOLDEN COMMODORE
355,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
2STONEY
  • 25 POSTS
Hi, wondering how do you wire a pair of 6x9 speakers to a 2-channel amp in case I've done something wrong, other than the load is it the same as wiring subs? I just tried and the amp is getting power but no sounds coming out? Subs are off another amp no problems there.
May 27, 2024 at 12:45 AM
2STONEY
  • 25 POSTS
Also, my head unit has 3 RCA spots in the back, front rear and sw, subs r in the sw and I tried the second amps rcas in the rear spot?
May 27, 2024 at 12:57 AM
STEVE W.
  • 15,113 POSTS
What head unit do you have and what amp? Generally, RCA are used for signal interconnections not for speaker outputs if there is anything above a few watts,
Knowing what you have to work with might make it easier.
May 27, 2024 at 7:06 AM
2STONEY
  • 25 POSTS
Double din JVC head unit and 2 channel pioneer amp, will get the model numbers in morning.
Yea so how do people wire a amp for just speakers? (Wanting 6 speakers all up, 4 off the head unit and 2 off a amp).
May 27, 2024 at 9:13 AM
STEVE W.
  • 15,113 POSTS
Depends on the amp and its connections. Some are simple, others can be a mess. The catch with your installation is how the head unit is set up. The amp powering a set of subs and the head unit with the other 4 should be possible depending on the unit. Are you using any of the original parts?
May 27, 2024 at 9:54 AM
2STONEY
  • 25 POSTS
Xm5552zr amp of speaker, dk1800 amp for dubs, kwx850bt head unit.
May 27, 2024 at 4:30 PM
STEVE W.
  • 15,113 POSTS
Okay, for that unit if you are using the amp inside the unit, you connect up the 4 other speakers to the circled wires in the harness. So gray and gray black for right front, white and white, black for left front, purple and purple, black for right rear and green and green, black for left rear. (the ones with the black stripe go to the negative terminal on the speakers) Then the subwoofer amp gets fed from the SW RCA jacks. Then you have to use the 2-way crossover setting.
If you are using a different amp for the 4 speakers, then you use the RCA output jacks to connect the LF RF RR LR outputs to the correct line inputs on that amp and still set the head unit for 2-way crossover.
If you are not using the internal amp in the head unit, be sure to isolate the speaker wires and tape them up so they cannot short out on anything.
May 27, 2024 at 4:54 PM
2STONEY
  • 25 POSTS
Was planning to use the amp in the unit to run the four door speakers off the head unit and then another two 6x9 off the xm552zr 2channel, if that is possible?
May 28, 2024 at 1:28 AM
STEVE W.
  • 15,113 POSTS
So, you are thinking 4 door speakers plus 2 6X9 and then 2 subwoofers? Don't think that will work. Many of those style units cut the internal amp when you plug into the secondary outputs. So, if you plug into the "rear" RCA jacks for the XM amp and 6X9s it will turn off the internal amp and you lose the power to the 4 other speakers. The info doesn't say so, but many do that. You should be able to tell if you connect up just the 4 door speakers first, test that it works. Now plug in the subwoofers and see if they work. If you get 4 door speakers and subwoofer then for testing unplug the subwoofer and plug it into the rear speaker RCA connectors, do you still have all 4 door speakers? If not, then it does mute the output and limits you to just the 4 door speakers and the subwoofers.
May 28, 2024 at 4:21 AM
2STONEY
  • 25 POSTS
Oh, okay, I'll give it a go today. So if that doesn't work is the only way around that to change the head unit?
Jun 18, 2024 at 5:42 AM
2STONEY
  • 25 POSTS
What about rca Y splitters, would that not work?
Jun 18, 2024 at 5:43 AM
STEVE W.
  • 15,113 POSTS
Different head unit would likely still work the same way. What you normally do is determine how many pairs of speakers you want and then use one amp per pair. But extra speakers really doesn't improve the sound unless you have a large area and a way to tune the speakers to match the interior of the vehicle acoustically. The large speaker count in modern vehicles are due to them adding individual woofers, midrange and tweeters to create better sound to tune them to match the vehicle. The issue with splitters is that you can create problems if the units you are feeding the signals into are not perfectly matched in all ways. You get what is known as ground loop interference because they are not evenly matched. The result is hum or strange acoustic feedback.
Jun 18, 2024 at 9:05 AM
2STONEY
  • 25 POSTS
In that case could I not just get a ground loop isolator to stop that? Or try a relay to boost remote turn on signal?
Jun 21, 2024 at 2:43 AM
STEVE W.
  • 15,113 POSTS
Ground loop isolator might help but may not eliminate the problem. Usually the amps don't require a lot of power to turn them on if they have remote sense. If they don't you can use the remote wire (blue with white) to trigger a relay to turn them on and off.
Jun 21, 2024 at 1:52 PM
2STONEY
  • 25 POSTS
Okay, cool. thanks
Jun 22, 2024 at 9:43 PM
