I see, that's stuck pretty loud. Is this a factory radio you installed or an aftermarket type? I believe that control screen is the Integrated Center Switch or Stack module. You have controls on the steering wheel as well, correct? Service info lists a "Base" model Radio, a Premium model Radio, and a Premium 2 model Radio.
I can see options for Satellite radio and then a touch screen button for Climate Control, along with Phone and some other options I can't see, but you get the idea that there are a bunch of other modules that work along with this touch screen display, and they all communicate on a network together. Since climate controls, radio, any type of seat/comfort modules, etc., are not critical systems. So, it will be on a type of interior CANbus network that is of a slower speed (CAN-IHS 125k) than the network that controls the engine and transmission, ABS, SRS (airbag), Cluster, Steering Control module, etc. Which is on the (CAN-C 500k) network.
If you did the installation and no programming was done, I'm sure that's what the issue is. The dealership will also have software updates for modules in the vehicle. There are always updates. But below are the OEM wiring diagrams for that CAN IHS network, if this is the Premium 2 Radio setup, the Volume control is done by the Integrated Center Stack Switch Bank module and the Integrated Center Stack module. (diagrams 3,4) and that info is transmitted over the network to the Radio.
Dec 28, 2023 at 3:50 PM
