I can shift the transmission into all of the gears, but the car will not move
1996 FORD EXPLORER
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
OTTIS710
  • 4 POSTS
I've changed the transmission filter, fluid and the neutral safety switch. The shift linkage doesn't appear to be the issue, but I could be wrong. any help would be fantastic (Eddie Bauer edition).
Apr 10, 2022 at 4:52 PM
I have seen the pressure control solenoid go out which will cause the transmission not to go onto gear. You will need to remove the transmission pan which this guide can show you how and I have left the instructions on how to change it out in the diagrams below.
and
https://www.2carpros.com/articles/automatic-transmission-problems
Apr 11, 2022 at 11:56 AM
OTTIS710
  • 4 POSTS
Hi Ken, thank you for the advice. come to find out it was very low on transmission fluid. But now another issue is at hand; when I do drive it's like something is behind me pulling me back as I accelerate, there isn't any power and it feels very sluggish. I can try to provide a video later today if that would be a better explanation of my issue.
Apr 13, 2022 at 7:13 AM
Apr 13, 2022 at 4:54 PM
OTTIS710
  • 4 POSTS
I'm uploading a video ignore the rattling it's a socket set not the car. The car will only go past 2,000 to shift into first gear then from 3,000 it slams into second gear and will not go past 2,000 RPMs, also will not top more than 35 MPH.
Apr 14, 2022 at 8:13 AM
OTTIS710
  • 4 POSTS
Video should be with this reply.
Apr 14, 2022 at 9:05 AM
This seems like the catalytic converter is clogged. To be sure this guide can help confirm the issue:
Let me know what happens and thanks for the video, it helped. Check out the diagrams (below).
Apr 14, 2022 at 11:10 AM
