Why was it recharged? If it was due to it not working because it was empty, was a leak repaired or just charged? First thing would be to check and see if it is still charged using a pressure gauge set. If you attach the gauges and it reads zero then you have a leak.
Sometimes you can find a leak by looking along the lines and fittings as well as at the condenser core in the front and look for oil residue. If there is nothing seen then the next step would be to add a small charge then use a sniffer to detect the leaking area.
From there you would have a starting point.
Mar 20, 2020 at 3:36 AM
