Hi I have 3 questions. Number one how do you take a crankshaft pulley off without a stap wrench to keep it from turning. Then how do you remove the wheel without a 3 jaw puller. I am trying to get into the timing cover so I can remove everything to inspect the camshaft. I had a lifter go so I need to know how bad it damaged the cam. Question 2 is I have removed all the head bolts and the heads will not come off I tried a screw driver in the intake port and it does not even budge is their a easier way to get them off. I have also hit it hard with a rubber mallet and nothing. Last question is their was no refrigerant in my a/c I know it has a leak somewhere so I am still looking. I am going to replace the seals is their a certain torque rating for these seals. This is all on a 1998 Chevy Camaro. This is a LS1 motor. Thanks.
Apr 20, 2014 at 11:23 PM
