Transmission will not shift into drive or reverese
2004 TOYOTA PRIUS
18,000 MILES • VR6 • 2WD
ATHENAHALL
My car turns on but the speedometer won’t show and it won’t let me go into drive or reverse. What should I do?
Apr 23, 2020 at 12:27 AM
We need to start with two things. First check for codes. If we have an issue with a sensor or switch we should have a code to point us in that direction. Here is a guide that will help on how to do this:
The next thing we need to do is have the battery load tested because that was a common cause of this issue. Here is a guide to help with that:
Let's start with these things and go from there. Hopefully we will have more to go on after we get this info. Thanks
Apr 23, 2020 at 8:56 AM
