Capacity oil for new A/C compressor
2014 MITSUBISHI OUTLANDER SPORT
120,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
PETROYADA
  • 66 POSTS
The A/C compressor for my car was failed and also we will replace with a new one, but for installation, I need the procedure.
1. I will be replaced by the new A/C compressor and A/C Dryer?
2. How the amount of oil will be charge into compressor?
3. If I refill the oil in the new compressor and reinstalled it so after vacuum, should be a bit charge oil or not?
Please inform me that how can I install a new compressor properly?
the VIN related to my car is : 4P3XTGA2WEE801499.
Jul 30, 2020 at 6:17 AM
Good morning,
I attached the nformation for you below. It takes 3 ounces of oil in the compressor.
Why are you replacing the compressor?
Jul 30, 2020 at 6:45 AM
PETROYADA
  • 66 POSTS
In idle mode the cooling is very low.
If i press the accelerate pedal until 2,000 RPM's, the cooling is normal.
Jul 31, 2020 at 2:06 PM
PETROYADA
  • 66 POSTS
The pressure from high side is too much.
So if I press the accelerate pedal until 2,000 RPM's, the pressure from high side goes to 35-45 psi.
Jul 31, 2020 at 2:10 PM
PETROYADA
  • 66 POSTS
The compressor was failed ? Or not?
Maybe, Just the accumulator Dryer should be replaced. It’s true?
Jul 31, 2020 at 2:12 PM
Can you give me the high and low side pressures? The pressures you listed are for the low side only.
Jul 31, 2020 at 2:13 PM
PETROYADA
  • 66 POSTS
I’m tired!
Jul 31, 2020 at 2:16 PM
Okay, we can continue tomorrow.
Jul 31, 2020 at 2:28 PM
PETROYADA
  • 66 POSTS
Thanks.
Jul 31, 2020 at 2:42 PM
PETROYADA
  • 66 POSTS
The low side pressure : 100-120 psi.
Jul 31, 2020 at 2:44 PM
PETROYADA
  • 66 POSTS
I'm tired of the air conditioner problems.
I’m ready for your concern.
Jul 31, 2020 at 2:47 PM
I need you to give me the high and low side readings with the engine running and the A/C on.
I would also like the readings with the engine off.
Jul 31, 2020 at 3:52 PM
PETROYADA
  • 66 POSTS
Sure.
I’m working at offshore now. I will be access to the A/C after 24 days.
Many thanks.
Aug 1, 2020 at 5:14 AM
You are welcome.
We will be here to help.
Aug 1, 2020 at 1:40 PM
