Capacitor discharge
2006 CADILLAC STS-V
133,000 MILES
FIBONACCI
  • 5 POSTS
I have been able to clear the check engine light, but still get the following:
Service:
Stability System
Tire Monitor (justified since one sensor is dead)
Vehicle Soon
Air Bag
Brake Assist
My question is basic. If I perform the Cap Discharge voodoo, Will my remote FOB still be operable. There is no physical ignition key on this model.
Jan 15, 2022 at 2:25 PM
AL514
  • 5,465 POSTS
Hello, you may run into more problems than you want, for one thing the codes for any components that have failed or have circuit issues are going to eventually come back after a number of key starts. Second the key fob on this model uses a rolling code method, also to program a key fob again or a new fob you have to have the mechanical key for the vehicle. So, your best bet is to diagnose the issues it is having, if things go wrong, you could be stuck with a car that won't start ever again. If you're getting codes, you can post the codes here and we can look up the criteria for setting those codes and give some direction. But with a missing mechanical key I wouldn't discharge the ECM's memory.
Jan 15, 2022 at 5:26 PM
FIBONACCI
  • 5 POSTS
I have the original mechanical key (and two duplicates) which I have used to add 2 additional FOBs. If all goes South, would I be able to use the FOB addition procedure to run the car again?
Jan 15, 2022 at 5:43 PM
FIBONACCI
  • 5 POSTS
I have been researching this for months, and find it hard to believe that no-one on the planet actually knows?
Jan 15, 2022 at 5:47 PM
I believe you are referring to a captive discharge. If that is the case, the key fobs won't be affected.
Jan 15, 2022 at 6:42 PM
FIBONACCI
  • 5 POSTS
Yes, I was referring to discharging the capacitors. Thank you, I am going to try and trust your answer and expertise.
Jan 15, 2022 at 6:45 PM
You are very welcome. If you have a chance, let us know how things work out for you.
Jan 15, 2022 at 7:25 PM
