Hesitates on take off and backfires
1995 HYUNDAI TRUCK
269,843 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RALPH CHAVARRIA
  • 4 POSTS
New distributor, rotor, wires,cap,plugs,idle air control valve, map sensor, TPS, oxygen sensor,knock sensor, timing set on point. starts but when i give it gas hesitates on take off and backfires. Help.
Jun 17, 2019 at 9:08 PM
Good morning,
I would start by checking the compression. It will tell us if the engine is internally food and if the valve timing is correct.
Did you verify the firing order?
https://www.2carpros.com/articles/engine-backfires-while-running
Jun 18, 2019 at 2:43 AM
RALPH CHAVARRIA
  • 4 POSTS
Yes, i did timing checked it five times.
Jun 19, 2019 at 12:01 AM
RALPH CHAVARRIA
  • 4 POSTS
I need to get a pressure testing device to check it.
Jun 19, 2019 at 12:02 AM
Okay, keep us updated.
Jun 19, 2019 at 2:42 AM
RALPH CHAVARRIA
  • 4 POSTS
Thank you Roy.
Jun 20, 2019 at 2:26 AM
You are welcome.
always glad to help.
Jun 20, 2019 at 3:42 AM
