Cannot find A/C leak
1998 BUICK CENTURY
75,000 MILES
KEVINDUBOSE
This car is the custom model. My car is losing Freon in a matter of days. I cannot seem to find where the leak is coming from, used the dye to try and find the leak but nothing showed up. any suggestions on where I should focus on looking for my model car?
Aug 24, 2017 at 10:39 AM
HARRY P
  • 2,292 POSTS
Where have you looked?
I would say that the most common leaks that I have seen are from the A/C condenser where the fins might have gotten damaged from hitting something, from the various valves/seals/o-rings throughout the piping, or from the compressor itself. Personally I have seen several with the leak in the piping or the compressor leaking from the main seal.
Also, when using a leak detector, you do have to use a UV light and glasses to see the leak. I did not know if you knew that or not, but most of those leak detectors require the light and glasses.
Aug 24, 2017 at 7:24 PM
