This is not the same engine that's in mine. the coolant jug is on the driver's side. all I could find is two ports none would fit the hose from the Freon can.
May 20, 2022 at 3:52 PM
SQM
CERTIFIED EXPERT
Can you tell me or upload pictures of where you found those 2 ports?
May 20, 2022 at 3:57 PM
BRANDONC75
MEMBER
One is behind the cover that you take off.
May 20, 2022 at 4:16 PM
SQM
CERTIFIED EXPERT
According to Alldata the low side service port should be the one under the engine cover. See below.
Image (Click to enlarge)
May 20, 2022 at 4:28 PM
BRANDONC75
MEMBER
Okay, thanks. I will look I must have missed it when I looked earlier.
May 20, 2022 at 4:43 PM
SQM
CERTIFIED EXPERT
Let me know if you are able to find it.
May 20, 2022 at 9:49 PM
BRANDONC75
MEMBER
This is what the engine looks like. I still can't find it, lol.
May 21, 2022 at 10:35 AM
SQM
CERTIFIED EXPERT
I am trying find other diagrams but there is just not enough info available.
Can you take a few more pictures of the top of the engine area from different angles? It should be towards the back of the engine closer to the firewall.
May 21, 2022 at 11:21 AM
BRANDONC75
MEMBER
Yes, the only ones I see are the two ports with the grey caps on it that won't fit. I've looked everywhere.
