I'm not real familiar with the vehicle because it isn't offered in the US. However, I try my best to help.
First, the most common cause of having a no spark condition is a faulty crankshaft position sensor. Now, since there was a lot of work just done, something could have been left disconnected.
Here is a link that explains in general how a crankshaft position sensor is replaced. Take a look through it and then try to locate the one on your vehicle.
I'm not sure what year your vehicle is, but if it is newer than a 1995, it should have an OBD2 diagnostic system. If it does and you have a live data scan tool, plug the scanner in and crank the engine. If the sensor is bad, in most cases you will not have an RPM signal.
May 19, 2021 at 2:27 PM
(Merged)
