Cannot switch from dash vents to defrost
2012 FORD F-150
200,000 MILES
RMOMMER
When I change the selector from dash vents to defrost it still blows out the dash. XLT package that doesn't have dual zone heat/cool.
Dec 18, 2021 at 4:53 PM
SQM
  • 6,383 POSTS
It sounds like you might have a faulty mode door actuator. The mode actuator is what changes the air flow from vent to defrost to floor.
It is likely stuck in the "on" position.
The mode door actuator is located under the dash on the driver the side footwell. Up towards the center console.
Thank you.
Dec 18, 2021 at 9:25 PM
RMOMMER
Install a new actuator and it still does it.
Dec 19, 2021 at 11:12 AM
SQM
  • 6,383 POSTS
The new actuator needs to be initialized properly; without it, it will not work correctly.
The ignition key must be off when replacing the actuator. Energizing the actuator before installation will cause the part to become positioned incorrectly and proper orientation will be lost. Incorrect actuator operation will result.
Another possibility is that the actual door might be jammed or has a broken gear, which does not allow it to turn even with the actuator operating correctly.
The only sure way to know would be to take apart the HVAC box and inspect/replace as necessary.
Dec 19, 2021 at 11:53 AM
RMOMMER
I followed all steps for initialization so it must be the actual door. I suppose it's behind the dash.
Dec 19, 2021 at 12:58 PM
You will need to do some pinpoint checks to be sure the voltage is getting to the motor.
I attached the diagram for you to view. Check the connector for power with the key on.
Dec 20, 2021 at 8:31 AM
