cannot shift gears without slight grinding after putting in first gear and at takeoff grinding noise continues so I have not used vehicle since. I checked the brake fluid, level is okay. I checked the slave cylinder for leaks, no leaks, bled the slave cylinder slightly less grinding noise, but I still cannot shift without grinding, Is there anything else I should check before changing the clutch?
May 31, 2016 at 12:36 PM
