cannot shift gears
2008 SCION TC
130,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
HENRYD316
cannot shift gears without slight grinding after putting in first gear and at takeoff grinding noise continues so I have not used vehicle since. I checked the brake fluid, level is okay. I checked the slave cylinder for leaks, no leaks, bled the slave cylinder slightly less grinding noise, but I still cannot shift without grinding, Is there anything else I should check before changing the clutch?
May 31, 2016 at 12:36 PM
If it is hard to shift into gear when running, check to see if it is easier with the engine off, If it shifts easily off, the clutch isn't fully disengaging. This is most likely the result of a weak slave or clutch MC.
May 31, 2016 at 8:46 PM
HENRYD316
Thank You very much for taking the time to answer my question
Jun 10, 2016 at 11:26 AM
This can also be caused by the clutch disc lining falling apart while will not allow the clutch to disengage as well. Please let us know what you find.
Best, Ken
Jun 11, 2016 at 5:18 PM
