When the van has started and running you cannot select any gears. When the ignition is off you can select a gear okay, depress the clutch and start the van, it will then go okay but will not be able to select a gear. You need to switch off to select a gear? Has been fine since this.
Oct 6, 2018 at 3:06 AM
