Multiple codes after sitting in a tow yard for three years?
2013 BMW 335
93,000 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
BMWGUY2323
I have these codes listed below. I have checked every fuse on the car, replaced the power supply module in the engine, replaced the wiring harness from the ecu to the Servotronix motor, i have put all new spark plugs in, cylinder 2 got a new fuel injector and ignition coil, new oxygen sensor,
The car got a new motor then got repossessed and sat in a tow yard for 3 years and I bought it at auction. I'm the only one to drive it with the new engine.
CODE DEFINITION STATUS
D016E4 Message Error (Status Distribution Longitudinal Torque Front Axle Rear
Axle, ID: ST_REPAT_XTRQ_FTAX_BAX) - Timeout INTERMITTENT
D014A1 Signal Error (Ist Position EPS, ID: AVL_PO_EPS) - Qualifier, 1 INTERMITTENT
FZD - Roof Function Center
801A4C SINE: Internal Supply Undervoltage, 1 PERMANENT
IHKA - Automatic Heater And Air Conditioning
E7146F K-CAN Message (STAT_RADIO KEY, 23A,FA): OP_KEY_BUT_SPFN
Invalid Signal INTERMITTENT
VTG - Transfer Case
440105 Calibration: Faulty, 0 PERMANENT
440117 4Wheel Drive Transfer Case Temporary Inoperative, 0 INTERMITTENT
440102 Oil Erosion, 0 PERMANENT
440100 CONTROL UNIT: Error Complete System, 0 PERMANENT
FEM-BODY - Front Electronic Module
804370 Compressor Valve: Short Circuit To Plus Or Line Break, 0 PERMANENT482394 Sensor - Rotor Position - Steering Angle - Loss Multiturn Value, 0 INTERMITTENT
KOMBI - Instrument Cluster
E11420 Instrument Cluster: Service Call Cannot Be Carried Out, 1 INTERMITTENT
RDC - Tyre Pressure Control
481F8F Wheel Electronic (Position Unknown) No Reception, 0 PERMANENT
DSC - Dynamic Stability Control
48068C Transfer Gearbox - Clutch Momentary Not Used, Possibly Overheating, 1 INTERMITTENT
480AB8 Internal Condition Management - Complete Monitoring Extent, 1 INTERMITTENT
D36D44 Signal (Longitudinal Torque Distribution, Front Axle/rear Axle, ID:
ST_REPAT_XTRQ_FTAX_BAX): Invalid INTERMITTENT
48097D Transfer Gearbox - Clutch Position Open, Only Rear Drive, 1 INTERMITTENT
D35A53 Signal Error (Actual Steering Angle, Front Axle, ID: AVL_STEA_FTAX):
4809AB DSC: Global Voltage Supply - Undervoltage INTERMITTENT
Apr 12, 2025 at 3:18 PM
These are a lot of codes, I would clear them and then turn the system on without cranking the engine over, then run the codes again, this will give us the most prevalent codes.
Also, I would check all fuses again with the systems on and if they are okay, I have seen the front control module cause all kinds of strange problems like you are having.
I would also look for water damage by looking under the carpet which is where many modules are located. Here is the footwell module location, I would disconnect the battery and remove the module electrical connectors and look for corrosion. Check out the images (below). Let us know how it goes.
Apr 13, 2025 at 11:59 AM
BMWGUY2323
Battery is fine and I have checked every fuse twice. I replaced the relay that's in front of the fuse box under the hood on the passenger side. There is no corrosion. There is no water damage. The abs, transmission codes, cylinder 2 misfire, and vvl low voltage are the ones always there.
Apr 14, 2025 at 1:06 AM
It sounds like the footwell module is out, please check out the post above, I updated it. You can get a preprogrammed unit by searching Google or Ebay. I would clear the codes and then turn the system on without starting the engine and run the codes again to help confirm the failure.
Apr 14, 2025 at 9:52 AM
