Can Loose Battery Terminal Cause These Problems?
2011 KIA OPTIMA
112,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JAYFIVS
  • 8 POSTS
Today while driving, my Electronic Power Steering light came on and my wheel wouldn't turn.
I turned my car off and tried to restart it, but it wouldn't turn over or start at all afterwards.
After 20 minutes or so of playing with my car battery and wheel; I was able to get my car started and began trying to drive home again. It drove great until I got to a stop light, then all my dash lights popped up.
Thankfully my car was still on and I was able to keep driving until I got to a stop sign, where my EPS light came back on and my whole car shut off again while driving.
I had it towed home and looked at it again and noticed my Negative battery terminal was loose (enough to move around with a hand). I tightened it back on to where it doesn't move and tried cranking my car and it came on perfectly fine; but now I'm worried to drive it with the fear it might die in the middle of the road again.
Any advice?
Sep 5, 2025 at 2:30 PM
CARADIODOC
  • 34,306 POSTS
It sounds like you have the diagnosed correctly already. That cable clamp should be tightened right away as it's the battery that helps the voltage regulator from allowing system voltage from going too high. Depending on the design of the charging system, it can also allow system voltage to drop too low. At that point computers begin to shut down or do weird things. When they turn themselves off, they turn on their warning lights to let you know.
This can also lead to minor current surges that blow fuses when there's really no actual problem. Once you have both cable clamps cleaned and tightened, if anything doesn't work, start by checking the fuses. I can help with that if necessary.
Here's links to some related articles you might find of interest:
Sep 5, 2025 at 2:50 PM
JAYFIVS
  • 8 POSTS
Hey Caradiodoc,
I did go ahead and tighten down the terminal to the battery and it cranked right up again with no issues.
I was just mostly worried to try and drive it again as it cranked up a few times as well like normal when the terminal was loose, but shut down while driving 10-20 minutes later.
Just in case the loose terminal WASN'T the issue, I didn't want to drive it and have my car shut completely off again while going down a road/get stranded again. With your knowledge you think that was definitely the issue or is there anything else I should potentially check before getting back onto the road?
Sep 5, 2025 at 2:53 PM
CARADIODOC
  • 34,306 POSTS
The battery is the key component in holding system voltage steady. To get technical for a moment, all "AC generators" develop three-phase output with a waveform that looks like the top one in my drawing below. You won't be tested on this later, but the generator's output varies between 14.0 and 14.5 volts. The battery smooths that out to hold system voltage steady.
When the battery is missing from the circuit, as in a loose cable clamp, it's up to the voltage regulator to do that job on its own. That rarely works. On some car models, the regulator "sees" the 14.0 volts and tries to increase system voltage by making the generator work harder. Even though the result is output voltage rises, the regulator still sees a voltage that's too low, so it keeps on and keeps on raising generator output. Under the right conditions system voltage can go higher than 30 volts. That will damage computers and burn out any bulbs that are on. One variable in that list of "right conditions" is engine speed. All generators are very inefficient at lower speeds, so that's where less damage is going to occur.
On some car models, the voltage regulators respond to the high points on my waveform, 14.5 volts in this case. In response, they try to lower system voltage. There's a limit to how much control it has, so even though system voltage does go down, the regulator still sees the high points on the waveform, and it keeps on trying to lower the voltage until it's so low, the electric fuel pump, injectors, and electronic ignition begin to shut down. Generally this doesn't cause damage to other parts, but the engine will stop running or it will run very poorly.
1987 and newer GM vehicles have generators well-known to develop harmful voltage spikes. The battery must be in very good condition to dampen and absorb those spikes. When it gets old or has a loose cable, it can't clean up those spikes. Those spikes can damage the generator and interfere with computer sensor signals. That's the extreme case.
Regardless, we know a loose cable is going to cause something unusual to happen. The hardest thing in their life is running the starter motor. If the engine cranks at a normal speed, everything else should be fine.
Sep 5, 2025 at 4:34 PM
JAYFIVS
  • 8 POSTS
As you guessed, I don't quite understand all of those technical terms hahaha. My main concern was with my EPS light kicking on/locking my wheel and my car not starting or shutting off while driving.
So just to be clear and make sure I understand correctly both of those issues were caused by the loose negative battery terminal and should not persist now that I have tightened it onto the post again?
Thanks again for all of your help!
Sep 5, 2025 at 5:32 PM
CARADIODOC
  • 34,306 POSTS
You're welcome. It's surprising there weren't more symptoms or more warning lights.
Please come back to see us with your next problem.
Sep 5, 2025 at 5:43 PM
