can i replace the side transmission pan gasket (tos186669) without dropping transmission?
1997 PONTIAC GRAND AM
150,000 MILES
DAVEFTW84
  • 4 POSTS
Car has been leaking tran fluid. I took the car to a mechanic and mechanic Said pan is fine and not dmg but said gasket is leaking. He had a hatd time naming gasket and told me its part number tos18669 . Told me he has to drop tran to reach it and looking at 500 for labor. Can I replace it without dropping tran?
Sep 18, 2013 at 4:44 PM
SATURNTECH9
  • 30,869 POSTS
If its the side cover gasket leaking?What size engine do you have?
Sep 18, 2013 at 5:57 PM
SATURNTECH9
  • 30,869 POSTS
The side cover faces the frame of the car when you try to remove it it hits the frame.Sometimes you can drop the subframe down and tilt it out.Its still a big job.
Sep 18, 2013 at 6:05 PM
DAVEFTW84
  • 4 POSTS
Its 4 cyl engine
Sep 18, 2013 at 6:25 PM
SATURNTECH9
  • 30,869 POSTS
Yeah the frame is in the way that's what makes it so it wwont just come right off.
Sep 18, 2013 at 6:37 PM
DAVEFTW84
  • 4 POSTS
I can't just sicome it or use some type of sealing product?
Sep 18, 2013 at 6:54 PM
SATURNTECH9
  • 30,869 POSTS
I would never add stop leak to a transmission. Also smearing silicone on the outside of the gasket isn't going to stop the leak.
Sep 18, 2013 at 7:22 PM
DAVEFTW84
  • 4 POSTS
so no Lucas oil additive? Thanks for help
Sep 18, 2013 at 7:37 PM
SATURNTECH9
  • 30,869 POSTS
No I wouldn't put that in the transmission.
Sep 18, 2013 at 7:51 PM
