The only way I can get you any pinouts for ECMs is if you have a VIN number for the vehicle the ECM came out of. I understand you're saying it's a bus, but All Data and/or Pro Demand requires a year, make, and model. Or a VIN to get any wiring diagrams, under 1992 GMC Truck there are 22 models listed.
There is listed a 1992 G 1500 1/2 Ton Van, G 2500 3/4 Ton Van, and G 3500 1 Ton Van. Under these three models there is listed for v8's- 305 5.0L, 350 5.7L,
Listed under Chevrolet Truck, there is listed a G-10 Van, G-20 Van, G-30 Van. V8's- 305 5.0L, 350 5.7L, so if you want the G-30 Van, I can get that, but there's no Buses listed.
The ECM pinouts are the older style also, so it listed as ECM Inputs, then a different one for ECM outputs.
Here are the ECM wiring diagrams for a 1992 G-30 5.7 liter. the other V8's are 6.2 Liter and 7.4 Liter. The first 3 diagrams are ECM Inputs. The last 4 are ECM outputs. These are listed in order directly from All Data, so save the first 3 in a separate folder so they don't get mixed up. I don't know how many pins this ECM has.
Under Powertrain management there is also listed. Fuel Control, Hot Fuel Handling Module, Ignition Controls, Powertrain Controls, Torque Converter Clutch (TCC), Transmission Control Module (TCM), Vehicle Speed Sensor Buffer (DRAC).
So, for example, under Ignition Control, it shows the ignition coil setup, EST Module (Electronic Spark Timing), the pickup coil, etc,. Whereas in the ECM Outputs diagram it will only show the EST harness plug. So, these other diagrams break down each individual system. I'm assuming you will want the Fuel Control extra diagrams as well. Let me know.
Jun 1, 2022 at 1:26 PM
