Absolutely. When there is no external leak, the cause is usually a leaking cylinder head gasket. There is a number of tests for that but you have described a real small leak. These tests might not work for such a small leak. The first one is a chemical test at the radiator. GM's engineers left the cap off most of their radiators, so you have to try to do this test at the reservoir. It involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If coolant is being lost through the head gasket, combustion gases are usually also getting into the cooling system. That will cause the fluid to turn bright yellow.
A better test when the leak is so small is to add a small bottle of dark purple dye to the coolant, then search a day or two later with a black light. The dye will show up as a bright yellow stain. If the head gasket is leaking, you will find the dye inside the tail pipe. Auto parts stores will have the dye for the fluid you want to test, and those that rent or borrow tools should have a black light.
Oct 9, 2017 at 8:25 PM
