Can a fuel injector cause an engine to seize
2006 AUDI A6
111,000 MILES • 3.2L • V6 • TURBO • 4WD • AUTOMATIC
MLMARTINEZ63
Cylinders three and five misfires. The engine has seized. There is fuel in the oil. Damage to cylinder three wall and a bent rod. What can be the cause of breakdown? And if the engine has seized is it possible to determine the cause of breakdown?
Jan 16, 2018 at 11:37 PM
STEVE W.
  • 15,113 POSTS
From your description the damage is already done. What happened is that a faulty injector was dumping a lot of fuel into the cylinder. This fuel took up all of the space in the combustion chamber and when the engine rotated over the piston hit that fuel. Because the fuel does not compress the force bent the piston rod instead. This puts the piston in the wrong position and damages the cylinder. The misfire in cylinder five is related as the highly pressurized fuel that bent the rod very likely broke the head gasket between the cylinders as well.
The hard part would be to determine why the injector failed. That could be an electrical issue or a mechanical failure in the injector.
Jan 17, 2018 at 4:18 AM
MLMARTINEZ63
Thank you for all your help. My next question is. Is there any way possible to pin point the fuel injector as the cause for failure with a seized motor? My mechanic says there is no way to do that and my warranty company wants to tear down the motor further to try and pinpoint the fuel injector as the cause. Everything is covered in my warranty but the fuel injectors. If they can not determine it was a fuel injector they have to honor my warranty. Would the motor have to be running to determine it was the fuel injector?
Jan 17, 2018 at 2:30 PM
STEVE W.
  • 15,113 POSTS
It would depend a lot on how it failed. Pulling the injectors to do a bench flow test might work but you could not be sure that removing them does not change the failure to a working unit. I doubt the freeze frame data that goes with the misfires would show anything but it might. You would need to look at the data and see if it shows the fuel trim trying to lean out that side of the engine in response to the over fueling issue.
Beyond that I do not know of a way to tell without tearing the engine down to actually look at the damage.
I would have an attorney look at that warranty as well. You might have a legal option that is not obvious.
Jan 17, 2018 at 5:05 PM
MLMARTINEZ63
Thank you so much Steve. I appreciate your help. You have a wonderful night.
Jan 17, 2018 at 7:23 PM
