can you replace a camshaft in a 2.2l 2000 chevy s10 without pulling engine is so please tell me how?
Apr 27, 2013 at 9:00 AM
HMAC300
CERTIFIED EXPERT
you have to pull the cylinder head and replace it like that so it mean s draining coolant and bunch of other stuff.
Apr 27, 2013 at 10:15 AM
BIGBYRD4412
MEMBER
how do you get the oil pump shaft out of the way?
Apr 27, 2013 at 10:23 AM
HMAC300
CERTIFIED EXPERT
on the right side of block there is an oil pump drive it ihas one bolt that holds it in and it pulls out. you have to remove the cylinder head so you can take all the lifters out. check for lifter bore wear prior to removing lifters. like look to see if they are allin theretight.
