Received an engine code for P0340/0344 for the camshaft signal. I have replaced the sensor but code it still there. I've cleared it and driven it, no problems with performance, fuel mileage or starting. After next startup, codes come back. I would like to check the wiring from the CPS to PCM next but no diagram can be found so if someone might have one and also what the readings from the sensor should be. Or tip on what else it might be?
May 21, 2021 at 10:43 AM
