Camshaft sensor replacement
2006 FORD C-MAX
100,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
STAN11
Hi, my car has probably a bad camshaft sensor, my mechanic is 95% sure.
Can I replace it myself, is it an easy job?
Does it require anything special, any computer work?
Feb 4, 2020 at 8:20 AM
This job is not bad. this guide will help walk you through the repair with diagrams below to show the location on your car:
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Feb 4, 2020 at 3:48 PM
STAN11
Thank you, it is very helpful.
Will the engine check light go off automatically when I change the sensor?
Feb 6, 2020 at 2:04 AM
No, you will need to clear the codes. here is a video to help you see how:
https://youtu.be/ahK_eucFi-k
Feb 6, 2020 at 10:25 AM
