Camshaft sensor location
1992 CHEVROLET LUMINA
110,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JSZCZERBA
Replaced crank sensor ran good. after cold days started one time, idled half hour turned off, would not restart. It acts like before crank sensor change. is there a cam sensor and where is it located?
Feb 4, 2019 at 1:09 PM
Good afternoon,
Do you have spark?
Can you hear the fuel pump run when you turn the key on?
Feb 4, 2019 at 1:47 PM
JSZCZERBA
Replaced crank sensor again, starts and runs two miles. when restarted, would not idle in drive. after many starts could drive gently at low speed. I am now replacing the coils. see what happens. thanks
Feb 11, 2019 at 1:56 PM
Okay, keep me updated and let me know if there are any codes set.
Feb 11, 2019 at 2:02 PM
