Code P0016 need camshaft position sensor location
2015 SUBARU WRX
52,600 MILES • 2.0L • 4 CYL • 4WD • MANUAL
TELEAN69
I've got P0016 with check engine light on and want to replace them. Not sure where they located. How many are them ? Thanks for your help.
Aug 29, 2020 at 10:23 PM
I attached the info. This is a code for bank 1 so you are going to be looking at the intake sensor. I also attached the location so let us know if you need more info. Thanks
Aug 30, 2020 at 7:46 AM
TELEAN69
Thank you so much. I'm going to check after work.
Aug 30, 2020 at 8:36 AM
