Camshaft position sensor harness plug wiring order and color needed?
2007 HONDA CIVIC
100,132 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
AUSTIN GRAY
MEMBER
1 POST
FOLLOW
I mistakenly broke the harness wire plug of my camshaft position sensor while trying to change the sensor, I need the combination and color guide.
Apr 17, 2023 at 11:17 AM
AL514
CERTIFIED EXPERT
Hello, here is the harness plug for the cam sensor, plus the wiring diagrams for it. The highlighted wire Pin 3 is the power feed wire. There should be 12volts with the Key On.
