Camshaft position sensor bank 1?
2018 VOLKSWAGEN ATLAS
12,500 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
Please help me locate the camshaft position sensor bank 1
Apr 15, 2026 at 5:14 PM
The camshaft sensor bank 1 is on the left rear of the cylinder head, but if you are getting a code for this it might be the timing chain system is having an issue, does the engine make a slight rattle noise when at idle when the engine is cold? If so this can be an issue. Can I ask which code you are getting? Check out the images (below). Please let us know what happens.
Apr 16, 2026 at 9:36 AM
The code I am getting is P0366, but I can’t find anything online point out the sensor so I can change it. I found 2 sensors on the driver side of the engine but I believe should be a total of 4. I need to change bank 1 and from any sources I see online that should be on the passenger side but there just isn’t much information I find on my specific vehicle. And it isn’t starting due to I’m hoping that sensor.
Apr 17, 2026 at 10:19 AM
So this engine is a strange one, it says v6 but there is only one cylinder head and 2 camshafts. so the two positions I sent you are the only ones on the engine.
So the code P0366, the code definition is Camshaft Position Sensor “B” Circuit Range/Performance, Bank 1.
So sensor B would be on the left side of the plate while facing it. Does the engine have a rattle noise at idle cold? Check out the images (below). Please let us know what happens.
Apr 18, 2026 at 8:57 AM
I put the new sensor in that spot (tried both actually) and the car still didn’t start. Do I need to clear the code with OBD to reset it with the new sensor installed? The car doesn’t start now so can’t say if has a rattle but I didn’t notice any unusual noises when it was working.
Apr 21, 2026 at 1:22 PM
Did the engine run before the sensor change? It says the sensor are plug and play, or at the least the engine should run with a check engine light on. How does it sound cranking over? normal? Can you please upload a short video from under the hood of the engine cranking so I can see if the engine is hurt or not? Please go over this video as well.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Apr 22, 2026 at 7:27 AM
