The codes are related to the items I indicated in my pic. However, did they all come on at the same time? The variable valve timing solenoid for both banks 1 and 2 are shown and they usually don't fail at the same time. Note that the cam sensor codes may be the result of the VVT codes and the opposite.
Let me know. Also, make sure the engine oil is both clean and full. Additionally, disconnect the connectors to all of the sensors one at a time and inspect the inside of the connection to see if there is any corrosion or damage. If they are good, I would start with replacing the camshaft position sensors. I say sensors because the codes are for both banks of the engine.
Jul 9, 2023 at 6:37 PM
