Good afternoon,
I attached the possibilities for you below as well as the procedure for the cam sensor.
Check the voltage to the sensor as well. You need 5 volts with the key on.
The sensor is on the back of the left cylinder head. There are 2. If I were you, I would replace both while you are there.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Camshaft Position (CMP) Sensor - 5.0L (4V)
Removal
Both RH and LH intake Camshaft Position (CMP) sensors and RH exhaust CMP (Camshaft Position) sensor
1. Disconnect the Camshaft Position (CMP) sensor electrical connector.
2. Remove the bolt and the CMP (Camshaft Position) sensor.
LH exhaust Camshaft Position (CMP) sensor
3. Position the vehicle on a hoist. For additional information, refer to vehicle Jacking and Lifting. See: Vehicle Lifting > Procedures > Jacking and Lifting
4. If equipped with 4 wheel drive, index-mark the front flange to the pinion flange.
5. If equipped with 4 wheel drive, remove the 6 front flange-to-pinion flange bolts and 2 washers and position the driveshaft aside.
Discard the 6 bolts and 2 washers
6. Remove the 2 bolts and the LH heat shield from the rear of the LH cylinder head.
7. Disconnect the CMP (Camshaft Position) sensor electrical connector.
8. Remove the 2 transmission support insulator nuts.
9. Remove the CMP (Camshaft Position) bolt.
10. NOTE: Make sure the transmission jack contacts the outer ribs of the transmission fluid pan.
Position a suitable high-lift transmission jack under the transmission. Raise the transmission until the CMP (Camshaft Position) sensor can be removed.
Remove the CMP (Camshaft Position) sensor.
Installation
1. NOTE: The bolt must be torqued while the transmission is raised
Position the Camshaft Position (CMP) sensor and install the bolt.
Tighten to 10 Nm (89 lb-in).
2. Using the suitable high-lift transmission jack, lower the transmission and install the 2 transmission support insulator nuts.
Tighten to 103 Nm (75 lb-ft).
3. Connect the CMP (Camshaft Position) sensor electrical connector.
4. Position the LH heat shield onto the rear of the LH cylinder head and install the 2 bolts.
5. If equipped with 4 wheel drive, position back the driveshaft, align the index mark and install 2 washers and 6 new bolts.
Tighten to 55 Nm (41 lb-ft).
Both RH and LH intake CMP (Camshaft Position) sensors and RH exhaust CMP (Camshaft Position) sensor
6. Position the CMP (Camshaft Position) sensor and install the bolt.
7. Connect the CMP (Camshaft Position) sensor electrical connector.
Oct 9, 2020 at 12:52 PM
