The code came up P0300 and that code is for my camshaft sensor and I already bought the sensor. I know that my engine has a camshaft sensor. I brought it to O'Reilly and they put it on VERI SCAN. That code P0300 indicates that there were too many random cylinder misfires within a predetermined period of time. and I could feel it and hear it. and before this sensor I replaced the ignition control module sensor, and the check engine light was on and the service engine light was on. Also, once changed the lights went out and it ran good for 20 miles, then the lights came back on. The ignition sensor was really bad, I couldn't put it in gear because it would stall out every time. once changed it didn't do it no more, so it fixed it then the same lights came back on. and it is shutting off but only a quarter as much. So, it is running better but the check engine and service lights are back on. I think I found it when you are in front of the car It is on the right side of the engine below my oil filter canister type to the left of that a few inches and you go a few more inches more to the left is the starter between those 2 and right next to camshaft sensor is the knock sensor to the left of it but right beside each other. I put a little compact mirror, and I can see the 2 together but there is only 3.1/2 to 4 inches for you to get in. The depth is about 6 inches to the sensors. If you took the fan, radiator, condenser out it would take 3 minutes to take the senso out and put it right back in. still in those 3 minutes. Now all the other years of that engine they have the camshaft sensor 2000,2001, 2003, 2005. And you are telling me the 2004 it doesn't have the camshaft sensor. Can you please keep looking? the sensor looks the same in all of them. Do you know what the size of that bolt head on the rest of the years that I have said. It is a 7,8,9,10, mm If I find the right socket the first time, I get it on that bolt I will get it out. And then I just have to put it back in one time. can you please get me the right size mm socket that goes on the head of that bolt Please as soon as you can. with the mirror what I see is what the new sensor looks like. If there was room to keep the little mirror and put the ratchet in at the same time it would work out it still would be better than with no mirror.
Dec 3, 2024 at 3:00 AM
