Camshaft/ Crankshaft alignment
1995 HONDA PASSPORT
133,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
MATT WILDER
I removed the belt before i lined up the alignment marks on the crankshaft and camshafts. I now have them lined up in the correct position, with the belt off. I need to know how to make sure everything is aligned and that the pistons are in the correct position. Im not sure if by turning the camshafts are raising and lowering each individual piston and i should keep turning until the proper ones are where the need to be. Does this make sense?
Aug 24, 2016 at 8:53 PM
SATURNTECH9
  • 30,869 POSTS
The cams open and close the valves not move the pistons the crankshaft moves the pistons.if you have all the timing marks aligned then your good to go.
Aug 24, 2016 at 9:40 PM
