Camshaft adjuster housing seal
2013 MERCEDES BENZ C36
95,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
SNIPER7799_9977
  • 8 POSTS
I've replaced both valve covers and noticed an oil leak on both camshaft adjusters. Do the cams need locked before removing the covers to replace the seals?
Mar 8, 2022 at 2:21 PM
Is this a C63? I believe by accident you transposed the model above. I just want to confirm I have the right vehicle.
If you are not removing the timing chain, there isn't a need to lock the cams in place.
Let me know if that helps and if I have the correct vehicle.
Mar 8, 2022 at 8:42 PM
