Two days ago check engine light came on. Within an hour, the car started running horribly and engine was chattering. I put the diagnostic on it and it threw several codes. Cam sensor, crank sensor, 02 sensor, EVAP, cylinder four misfire, and bank 1 running lean. I talked to my buddy who said could just be the crank sensor throwing everything off. I changed one but was told there are two. I have checked diagrams but the other sensor is not where they show. Please help. And do you think it is just the cam sensor causing all that? Before this I have had no issues with the car. Oh, the sensor I changed was on the passenger side at the front of the front valve cover.
Jun 8, 2018 at 7:12 AM
