Where is the cam sensor located at on a the vehicle listed above V8 5.2?
May 17, 2019 at 5:42 AM
STEVE W.
CERTIFIED EXPERT
Welcome back to 2CarPros. The CPS is on the front of the engine behind the front generator bracket. If you have a code for it I would look at the jumper harness first as the connectors get corroded.
Image (Click to enlarge)
May 17, 2019 at 6:31 AM
WIGGINS DONNA
MEMBER
Thank you.
May 17, 2019 at 7:01 AM
STEVE W.
CERTIFIED EXPERT
You're welcome. What is the issue you are having?
May 18, 2019 at 7:34 PM
WIGGINS DONNA
MEMBER
Where would I find engine control relay on the 2005 Buick Rainier V8 engine 5.3
May 20, 2019 at 7:15 AM
STEVE W.
CERTIFIED EXPERT
All of the engine power and control relays and fuses are in the underhood fuse and relay block. However there is not relay labelled as the Engine Control Relay.
