I keep getting cam sensor out of range code?
2000 HONDA ACCORD
212,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
CHRIS SPENCER
My car is very hard to crank . Once cranked it runs okay until I put in gear, then it shuts off. i keep getting cam sensor out of range code? I have changed distributor but no different.
Jan 18, 2018 at 6:20 AM
STEVE W.
  • 15,113 POSTS
I would look over the wiring to the distributor and the connections. The description that it starts hard but once started shuts off as soon as you put in gear sounds like the motion of the engine may be flexing a broken/loose wire and causing this. You might look at the wiring near the shift linkage and that area as well. Another test would be to get it started then see if moving the engine wiring slightly shuts it off.
Oct 12, 2020 at 11:28 AM
