I am in the process of rebuilding my 351w (with help from your 302 stroker video, thank you!) and would like some advice on cam selection. It will be a stock rebuild, bored .020 over, 4V 600cfm, factory exhaust manifolds. I am looking for a near-stock replacement cam, which provides good idle and vacuum (lots of vacuum stuff on a Cougar). I am considering the Summit 4400 since it is close to factory specs and has an LSA of 112 degrees. I would like your opinion, and if there are other options I should consider. Thanks!
Dec 23, 2022 at 10:59 AM
