Truck will not start every time/coughs (small backfire). mechanic read diagnostic 'high voltage on or at cam sensor. Where is it located?
Dec 10, 2017 at 5:43 PM
CERTIFIED EXPERT
Rear top of the engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Dec 11, 2017 at 6:16 PM
ASKEWDIVERGENT
MEMBER
V8 four wheel drive automatic 130,000 miles.
Where can I find the camshaft position sensor on a my truck listed above? It a 2500 5.7L engine. I would like to take the old one out so I can ensure that I have the right part before I order a new one. Thanks
Sep 7, 2020 at 11:47 AM
(Merged)
BRIAN 1
CERTIFIED EXPERT
This cannot be a 5.7 they did not offer 5.7 in 1999. only engines were 4.8,5.3,6.0 and 4.3.what is the eighth VIN number digit. double check and post back and I will answer your question.
(Merged)
ASKEWDIVERGENT
MEMBER
My mistake, it is a 6.0 L, 8th VIN digit is U.
The check engine light has cleared, but the error code P-0343 is still in (tried clearing and is comes back).
GM parts direct gives me three different parts for the camshaft position sensor listed for my vehicle. Any ideas which is the right one?
(Merged)
BRIAN 1
CERTIFIED EXPERT
could try calling the dealer and they could give you the part number. the camshaft position sensor is located at the back top part of the engine block, directly behind the intake manifold. post back with any other questions.
(Merged)
BRIAN 1
CERTIFIED EXPERT
(Merged)
RENETTAJ
MEMBER
1 POST
Truck was hesitating as you accelerated, then would shut down like it ran out of gas after driving a couple of miles, only to start again minutes later. I was told to replace:
coolant sensor,camshaft sensor, crankshaft sensor, spark plugs, and to adjust the timing. Having done this, the truck turns over but doesn't start. Any ideas? I am at the end of my rope. Many Thanks, Renetta
(Merged)
LGCASA
MEMBER
Yes, they offered a 5.7 in 1999 It is in the distributor. Pull cap pull rotor that piece that the plug is plugged into is the cam sensor. Chevrolet did not know were else to put it at the time. the 5.7 is in 4x4 and 3/4 HD pu and 1 ton vans.
(Merged)
FACTORYJACK
CERTIFIED EXPERT
Don't know why you were requested to replace all the parts. You will have to start with the basics at this point, and what is causing it not to start. Check for spark on one or more plugs, and check for fuel pressure of 55-60 psi.
(Merged)
SNAKE69
MEMBER
Electrical problem
1997 Chevy Silverado V8 Four Wheel Drive Automatic
where is the camshaft sensor located
Sep 7, 2020 at 11:48 AM
(Merged)
IMPALASS
CERTIFIED EXPERT
Hello
First, to better assist you I need to know if this is your specific vehicle, is it a 1500, 2500 etc, and your specific engine by liter.example is it a 5.4L 6.0L 7.3L etc gas or DSL and what is the 8th digit of your VIN.
(Merged)
SNAKE69
MEMBER
it is a 1997 z71 4x4 it has a 5.7L
(Merged)
IMPALASS
CERTIFIED EXPERT
Hello
(Merged)
WFIELD322
MEMBER
since i have owned the truck it has gotten crappy gas milage so i have been trying to do some small thing to help that. i have done a tune up, flushed engine, and changed all filters more than once. i took it to see if there were any dtc's last week and it came up with "camshaft to crankshaft postion coralation fault" now i don't know exactly what the means but it sounded like it was either the cam and crank sensors or the timing chain. so i took the easier option first... the sensors. the truck was running before but afterwards it would not run. i took it back out and put the old one back in and it would still not run. it turns over but acts like there is no spark, but i know all the wires are in the right spot, there is spark and it has good compression. i need to get this fixed asap so any help would be great.
(Merged)
JETSA
MEMBER
That code usually indicated camshaft retard timing is off. The distributor is supposed to be set at 0 degrees +/- 8 degrees. Anything above or below that will set that code. Usually the only way the timing gets out of specs is when the distributor has been removed and reinstalled incorrectly (usually after an intake manifold gasket replacement job). You need a scanner to read camshaft retard to see how far off it is. If it is at 34 (I think thats the max), usually a fuse is blown. Check the Engine1 fuse and the ECM1 fuse in the underhood fuse block for being blown.
EDIT:Forgot. Also while your at it, pull the distributor cap and grab the rotor and try moving it side to side. There should be little to no side to side movement. If there is any, the distributor bushing is worn out and the distributor needs to be replaced.
(Merged)
WFIELD322
MEMBER
the fuses were all fine and the distributor it squre to the back of the firewall and we have not touched the distributor. just the cap rotor and the sensor. there is maybe an eigth inch of movment if you turn it and about the same if you pull up.
(Merged)
JETSA
MEMBER
What about side to side movement while grabbing the rotor? Not turning it or pulling up on it. Basically you have a round shaft with a bushing around it to keep it from moving side to side. If this bushing wears out, then you will be able to move the rotor which is attached to the shaft and this is no good.
(Merged)
WFIELD322
MEMBER
well i did not notice any side to side movment but i will check for sure. if there is should i take it to somone who has a computer to check the timing to put a new distributor in it? and should i go have the timing checked if it doesn't? would something lke this make bad gas milage?
(Merged)
JETSA
MEMBER
Well, if you are mechanically inclined we can work through the installation here, but eventually you will need someone with a scanner to read the camshaft retard to make sure the installation is correct.
The truck you have isnt going to get anywhere near great fuel mileage. 4wd doesnt help much with gas mileage.
(Merged)
WFIELD322
MEMBER
well i am know i can put the distributor in i just dont have the time. i have a friend with the same exact truck who can get 20 an the highway. when i said bad i meant close to 10/gal. it also will not pull a trailer to save its life.
(Merged)
JETSA
MEMBER
Sorry for my double post. Computer lag.
If your getting that bad of gas mileage you should also be noticing it is running bad. If the distributor was that far off, I could see bad mileage and running badly, but it would have to be way off, so Im thinking that is not the main cause of your bad gas mileage. A problem yes, but not the main issue for mileage.
