Cam gears and cylinder head
2003 KIA SORENTO
200,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DAVID TODD
  • 13 POSTS
Yes the tensioner pin is pulled and you have sent those pictures to me already.I have a service manual that shows me all that and much more, but no one has told me how to get the tension back in my cam gears on the left bank, please tell me how to do that. Ken L, you told me that there should be tension when I set the timing, those gears have no resistance the timing marks line up and I don't have to put a wrench one on either gear.The first time I ever put the motor in time before the second time the belt broke all 4 cam gears had resistance on them. This is the second time putting this motor in time and the left bank has no resistance the marks just line up. This is a different head because when the belt broke the head spun out and bent 2 valves. I clamped the gears on the new head so I know they are not spun out. Can you please tell me how to fix this. This car is all I got, thank you
Aug 17, 2022 at 9:59 PM
