Cam gear moved on the cam?
2011 MAZDA 3
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
NOVACAINE
Me and my buddy are replacing the VVT gear, and the cam moved at one point when trying to pull the gear off. Does anyone know how to realign the cams and crank with the VVT gear?
Aug 17, 2023 at 6:11 PM
Yep, it is a procedure. here are the instructions on how to replace and retime the VVT actuator. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 18, 2023 at 11:25 AM
NOVACAINE
Thank you! I'll for sure be back again if I have any more questions! Thanks a bunch!
Aug 21, 2023 at 3:29 PM
You are welcome. Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 22, 2023 at 10:48 AM
