Hello I have the GS model 2.0/4 cylinder 16 valve dual overhead cam non turbo.
I bought the car non running was told that on the way home from work while in motion the car just shut off and never started again they said there was no power surge or loss, no motor stumble. it was as if the key was just shut off and car just rolled to a stop and had to be towed home that is all i know. So far i replaced the fuel pump, fuel filter checked and cleaned the injectors cleaned the EGR valve changed the plugs and checked the ignition coil pack and plug wire's they are good. only thing i can think of is cam or crank shaft position sensors. my question is, how many of each does this particular model have and where are they located at on the vehicle? if you can shed some light on this that would be extremely helpful and appreciated. also, if I missed something else perhaps I should have checked any advice would be also gratefully appreciated and welcome. thank you. although I have to add I also spray starter fluid into the throttle body in the vehicle the vehicle seems as if it wants to start runs for about two seconds then backfires and shuts off. not sure if this is relative to anything but just giving as much information as I can.
Feb 8, 2019 at 3:40 PM
