2014 ford focus. crank no start. did a compression test because it is giving a p2610 code. there is no compression. no water in oil so i don't think the head is blown or warped. did a olms of resistance test on the camshaft sensor at 20k olms. got a reading of 6.88 on one and 7.48 on another. does this mean they are good or do they need to be replaced. goin to test the crank shaft positioning sensor as well. the plugs are getting 5 volts so i know that is not a problem neither. any input on what i should do would be appreciated.
Jun 5, 2023 at 1:54 PM
